ORIGINAL: whatala
Thanks very much again opjose.
So, what do you recommend for the motor for this plane?
They are listed Hyperion HP 2213/16 and I have problem to find them. They are discontinue.
Very appreciate for your feedback.
Jason
Here is how I would configure it....
I would use this motor: [link=http://www.nitroplanes.com/mo258brmo.html]Click me![/link]
Though Nitro is out of them at the moment, they seem to frequently restock them. I purchased 2 of them and 2 of the Monster Power 32's a couple of weeks ago.
I would run two 14.8v 3850mAh LiPo packs one for each ESC.
I would install two 45A+ ESC's.
Why 45? As you increase the voltage to 14.8v, the total current capacity drops, so purchasing a 45A+ ESC assures you will not blow up the ESC.
Then prop the system to pull about 37-40 full throttle.
That will give you about 550 watts per motor.
That's 166 watts/lb so you have plenty of power and great flight times!
