RCU Forums - View Single Post - How hot does the ignition module get?
Old 09-23-2009 | 03:36 PM
leedees's Avatar
leedees
Default RE: How hot does the ignition module get?
ORIGINAL: arobatx
ORIGINAL: leedees
I am using the stock ignition module with the Zenoah G20. The angle of the fuel inlet on the carb is such that the fuel line will rest against the front of the ignition module.
Will this cause any problems, i.e. too hot for the fuel line etc?
The inlet nipple on your carb is a press fit. Though it is snug, it will move. You can turn it to better suit your installation. Just be careful, the plastic on the OEM inlet nipples can crack, grab and turn it at the base, not the bend.
I wondered about turning the fuel inlet nipple, that would help solve the problem in this installation as I have no good options for putting the ignition elsewhere on the firewall. I am building the new H9 Taylorcraft and this is the first gasser I've done.
