RCU Forums - View Single Post - Official HPI MT2 Thread
Old 09-23-2009 | 04:58 PM
  #19837
wongy008
Default RE: Official HPI MT2 Thread
ORIGINAL: eminentguitar
I think that 18 is to much. What engine do you have in there? 18 might be ok with the tz or bb engines but if its the g3.0 or anything less 18 is to much. What spur gear are you using?
ORIGINAL: KeithjV
Ive got my slipper tightened almost all the way down.
18T would be too much, plus you would have to mod the engine mount because there wouldnt be enough room with the stock holes. wongy what engine are you running again?
If you loose power to the wheels you should always check the drive cups to make sure the screws havent come out. It will save you the time of taking the diffs apart if you dont have to.
im running the stock 18ss+ engine. ive been sent a excell spread sheet and if you guys say 18 being too much what about 17t. only thing is i dont wanna lose too much accelration either. its also got the stock 49t spur. would there be noticeable gains in speed using the 17t
keithjv your new bits look awesome. cant wait to get mine now.
