Hi heres my apache 24 converted to brushless..I am using a 3300KV motor and a 35amp seaking esc...I put flex cabe and turn fin as seen in photos.
My problem is for some reason it feels like it don't float on the water serface it runs deep...what can i do?
Also i have a CF 40 prop on it and the esc stays 89deg and motor gets 140deg max ... I am thinking maybe the prop is to big and the motors RPM is not getting to full Rpm? I see the proboat widow maker uses almost the same set up but uses a smaller prop?
Any help will be great.
