RE: Need help with an O.S. .61 RF
I have an Atlanta that was a pain in the.. butt. Rossi FIRE mounteed inverted with pipe, tank behind firewall. Ran great on the ground in the air it would surge and die. I moved the tap around, same thing. I ended up adding a Perry oscillating pump, problem solved. Later the original owner said that set up needs a pump.
DM
