RCU Forums - View Single Post - FUNJET
Thread: FUNJET
Old 09-24-2009 | 04:21 AM
  #784
mk1spitfire's Avatar
mk1spitfire
Default RE: FUNJET
ORIGINAL: panzertank
can anyone help me im having a serious problem with my funjet. the problem is stays constantly out of trim (as far as in the use of ailerons). when im at high power settings its torques over to the left rapidly and when im at low power settings it pulls to the right very quickly ever since i reattached an elevon it contiues to do this. i am at a loss for what do to. does anyone have and recommedations on what i should do? any help will be appreciated. thanks
-PN
You could have a warped wing or buiding error but I think its the rotational force torque, that is doing this.
Infact I have the same problem on mine 2w-20 4s 4.7x4.7 cam prop.
I believe the solution is in our transmitter, assuming your transmiter can do mixes?
Throttle to aelerion mix.
Might be best to dissconnect motor and fire up full throttle and see which way + or - is needed to see the right roll correction deflection, fly and adjust low and high % input to counter this annoying effect
