RCU Forums - View Single Post - soldering woes
Thread: soldering woes
Old 06-30-2003 | 06:53 PM
r1morris
Default soldering woes
Big thing is a good heat source. I do most of my heavy soldering ,(non-electronic type) using a small Butane torch I found one in Lowes that works well. Also use soldering paste the type the type plumbers use. You have to clean the solder joint after but it makes for a smooth solder joint . If your using a soldering iron you may not have enough heat to do the job.
