soldering woes
I think you won't be able to get it hot enough for "silver solder" without melting the nylon. "Silver soldering" is really brazing which requires a higher temperature than soldering. Maybe you should try soft solder. it's much stronger than most people think and you won't have to heat it to such a high temp.......Seaplane
