RE: Fascination 50 ARF available
The elevator servo is built up to go over the rudder servo. As far as the engine mount!!!! If you have a small protractor you can find the angle of the mmts. The engine has an offset as shown the huge diagram. If you make a template and use the centerline of the mounts and line it up with the thrust line on the firewall. Making a full size template and rotating it to the angle found by the protractor should get you close to where it should be. Next fun step is installing the blind nuts. guaranteed to make you nuts. It does fly great, so in the end it is worth it
