RCU Forums - View Single Post - Servo Extension kit
Old 09-25-2009 | 09:42 AM
PaulD's Avatar
PaulD
My Feedback: (39)
Default RE: Servo Extension kit
I've had good results with this stuff:
http://www.airwildpilotshop.com/prod...00507081617571
http://www.airwildpilotshop.com/More...product&id=892
The crimper takes some patience to make sure you are getting the technique right. Key thing is not to remove the pins from the strip until after the first crimp which means you have to bend the pins you aren't using out of the way. You also need a good wire stripper that gives a nice clean cut on the insulation without nicking the fine copper wires.
PaulD
