RE: [Awaiting Approval]
Hi. Yes it is definetly the clutch. You adjust the carb etc. & this does not help at all. The car also does not idle properly. Remove the engine & just check if everything is in place as far as the clutch is concerned. The springs that hold the 2 shoe clutch together usually comes loose .
What type of clutch does your car use ?
