RCU Forums - View Single Post - Clueless in J Ville
Old 09-25-2009 | 10:23 PM
balsa brain
Default RE: Clueless in J Ville
[quote]ORIGINAL: balsa brain
Half time Indy 7, Jags 6, Incredible if you happen to be a Jags fan
Apparently what I have is not a Poulan, simply because it is not coming apart as avator said. I can't find any bolts holding it together.
The cylinder came off the case using a #27 torx bit going down through holes in the cooling fins. The cylinder is not a part of the case.
The muffler is held on with springs. The rod is a single piece with a roller bearing at the crank. Rear intake and rear exhaust.
I would post pictures of the engine but I don't have the camera software on this computer and I put it somewhere where I could not forget where it was. Right.
Again,thanks
Bill
A friend gave me three weed trimers today and an old Weed Eater blower that looked like crap. I took it apart and was surprised to find the engine looked like new. This one had four springs holding the muffler on and the piston has two rings.Other than that it was just like the one I tried to describe above. I don't think this engine has seen much run time.
Just from my description, can any of you folks tell me who made this engine?
Bill
