RCU Forums - View Single Post - What to do with a Hanno head with a stripped glow plug thread??
Old 09-25-2009 | 11:03 PM
Aurora_60's Avatar
Aurora_60
Default RE: What to do with a Hanno head with a stripped glow plug thread??
[quote]ORIGINAL: bjr_93tz
Thanks Atlanta60.
If anyone out there wants to know, I drilled the remaining thread out with a 7.5mm drill then drilled in an 8mm hole from the combustion chamber side stopping about 1.5mm short. In effect creating a stepped hole with a 0.25mm ledge. This also means the OD of the glow plug washer is slightly larger than the OD of the brass insert at the top so it effectively stops the insert (and glowplug) from ''falling'' into the cylinder while the step stops it ''popping'' out the top.
[quote]
Wow Brett, that is some really good forsight. I would have just drilled through. Now if I can get my brain to remember this one when I need to use it...
DM
