RE: COMPRESSION QUESTION
nor having a ring for that matter.
Two strokes without ring shouls have the same compression feeling, unless they have desaxe in the crankshaft.
Four strokes without ring have a totally different timing when turned the wrong way. i.e. the exhaust valve normally opens earlier than the inlet valve closes.
All this without ring.
If there is a ring, W8ye explained that.
