RE: ........... BELT CP V2 Thread..........
Joey HELP!
After 5 hours of playing with this thing this is what is going on, there is not enough movement in the swash plate in idle up, the swash hit’s the top and bottom before the stick is at full or minimum. This leaves ¼” of the top and bottom of the stick doing nothing but making the servos buzz. I don’t have a computer radio to adjust travel or end points like all the videos I have watched tell you to do.
nor. mode +12 +6
idle up -6 0 +11
I will not be flying this heli in 3d (idle up) can I just adjust the head for normal mode and forget about the idle up settings, there is enough travel of the swash plate in normal mode.
