RCU Forums - View Single Post - How difficult to fly off water?
Old 09-26-2009 | 09:14 PM
jester_s1
Moderator
Default RE: How difficult to fly off water?
You position the float front to back with the step under the CG when the plane is in a takeoff attitude. Sitting level, that will be about 1/2 inch back from the CG if you draw a line straight down. Then you get the wing incidence set to the top of the floats by adjusting the mount.
