RCU Forums - View Single Post - Escapade Assembly question
Old 09-26-2009 | 11:04 PM
Charlie P.'s Avatar
Charlie P.
Default RE: Escapade Assembly question
ORIGINAL: Jim_Purcha
How much expo should someone use for the typical trainer ie. superstar, tower trainer.
Jim
Depends upon the model and the pilot. If you are the type who tends to bang the sticks then low/high rates would be a better solution.
I don't put exponential on trainers (you want to "feel" the same control throw throughout when learning) but a sport model might benefit from 20%. A 3-D model maybe 60%. That's what I have on my Hot Stik.
Better to use low and high rates of 15 or 20% difference. Set the high rates to 100% throws and drop the low rates by 15 to 20%. My Futaba 9C allows me to use low rates without exponential and high rates with exponential. That's generally how I set up my sport models, but I go to as large a throw as I can work out on high rates rather than the recommended high rate. Then, depending how it flies, I'll tone it down with the servo end point/volume. And that, again, is a personal style choice for how you like a model to fly.
