SimJet 1200
Gentlemen,
I still have the 1200. I took it to Winamac hoping you might be there to look at it. Since it came back to me from overseas, after bearing replacement, it will not make full power. On my very crude test stand I got 6lbs (P80 showed 19lbs). I purchased and tried a new pump from flightworks with no change in output. I would like to be able to use this engine (so far it has only 14 flights) but right now it's not even a good paper weight.
If there's anything you can do please let me know. Thanks
Gary Szetlak
