RE: alright, so i need some advice please
If this is the SC10 RTR then the motor or ESC might have taken a dump. I heard that some the early tracks where over geared from the factory and it caused the electronics to over heat. Connect the motor direct to the battery and see if the motor runs. If it does run then the problem is most likely the ESC.
