RE: top flite corsair build questions
Joe,
Fired up the 120SP! I ran 1 gallon of wildcat 10 and then started on omega 10. It is running smooth and had little vibration even at the start! It is finally idling around 1400-1500. Top rpm is 5400 with a 18x12 prop. I want to try a 16x10 master air
3 blade. Have you tried to start yours from the front? Mine seems to turn over fairly easy.
