RE: Balancing Question
It depends on the plane, but if you want it to be exact ,use and incidence meter. Just make sure the center of the meter is over your prospective CG. Most of the time I try and use a small bubble level on a surface I know to be flat when the plane is level. Some planes just don't have a good spot.
David
