RCU Forums - View Single Post - Wing mounting challenges
Old 09-27-2009 | 09:01 PM
ppkk's Avatar
ppkk
Default Wing mounting challenges
Alright, this should be a simple task, but somehow I managed to screw it up: I am building a 4*-sixty, and when drilling holes in the wing & wing holding blocks, I managed to get them missaligned [:@].
In short, the holes that I made on the wing do not line up with those I made on the wing holding blocks. Long story, but while I was enlarging the holes in the wing holding blocks to install inserts (these ones: http://www3.towerhobbies.com/cgi-bin...?&I=LXE068&P=7) the holes got way out of alignment, so I have had to enlarge the holes on the wing to allow the nylon screws to line up with the inserts. The holes in the wing are now about twice the diameter (kinda oval shaped), and as a result, unless the screws are really tight - which I do not intent to do with nylon bolts - the wing can move a little side to side which is not good.
What is the best way of fixing this? I was going to glue washers with a 1/4" hole on top of the larger holes to lign up the screws to the blocks. Is there a better way of doing this?
Thanks!
