RE: Wing mounting challenges
Drill out the holes to fit an larger size dowel that will completely fill the miss drilled holes. One can go to either Lowes or Home Depot and find hardwood dowel relatively cheap. Once the holes are filled then redrill the holes to match the ones that were drilled in the wing.
