RCU Forums - View Single Post - 14MZ: Need to disable a switch at certain throttle position
Old 09-28-2009 | 07:13 AM
Corwin38
Default RE: 14MZ: Need to disable a switch at certain throttle position
Thanks for the post. I had failed to mention that I am using a retract servo on mechanical retracts. When I follow the steps you outline the servo still activates when I reach 30% throttle. Am I going to be able to make this work using a retract servo or should I swap it out for a servo with standard travel?
