RE: Balancing Question
Keep in mind that there is no "exact" CG location. Balance it however you normally do - if it's worked until now, you must be doing something right. But then FLY the model and see if it flies the way YOU want it to.
YOU might like it better with the CG moved slightly forward or aft - This is why there is a CG "Range"
