ORIGINAL: mikegordon10
Sometimes when using the HH cutter I start in the middle of the cut at the edge of the covering and cut toward the LE, TE or whatever at a shallow angle and cut till the tool reaches and merges with the LE or TE or whatever then runs along that surface to the end. Then you run it along the same surface in the opposite direction back to the other end. I know this sounds strange but it works rather easily and ends up dead on straight.
Another huge advantage of the HH tool is it uses many different parts of the razor blade so you get a lot more use out of the same blade. If you cut with just the end point of the razor you only have two parts and when they get dull your done with that one.
I am glad I didn't have to pony up the big bucks to get mine, man 16 bucks each has gotta be like 5 six packs of bear!
I beg to differ on your analysis of the beer buying power on 16 bucks. For 16 bucks you can get 14 1 littler bottles of Colt 45 or Steel Reserve. That's way more than the 5 six pack. In my younger college days, all I need was a Colt 45, a brown paperbag and a side walk. Who says you can't have fun for less than a buck, heh? DP
