RCU Forums - View Single Post - What to use for pull pull cable exits?
Old 06-30-2003 | 08:48 PM
Paul Cataldo
My Feedback: (10)
Default What to use for pull pull cable exits?
What do you guys normally do when a pull pull cable is going to exit the fuse where there is no wood, but only covering?
Do you add wood?
What else?
Should I just let it exit through a small hole in the wood, or do some of you use pushrod exit tubing?
Thanks fellas.
