977 problems/questions
I have been having some issues with my 977 charger. I read the instructions for it but still cannot figure out what is going wrong.
Charging: I have two 4600MaH NiMh batteries and if Ihook them both up and charge at 4 amps (one on a one on b) when they get done they are both at about 2000 Mah per hour according to the charger.
Same goes for my two 5000MaH batteries
If I hook them up and go to the MaH setting and put in 4600 or 5000 respectively I cannot get them both to charge at once. If Ido one at a time on channel A, sometimes they will charge to full capacity but sometimes they will not.
Discharging: It seems like some times when I try to discharge it will start to discharge and beep and be done in only a couple of seconds even though I know the batteries have not been run much from a full charge.
Any thoughts? Should Icontact MRC directly?
