RE: Let's see your work shop!
Here is my "workshop". As you can see it's quite compact (14 ft x 7 ft), but since I don't build giant scale anymore it is sufficiently large for me. Painting and heavy sanding jobs are done elsewhere. I prefer working with hand tools and have reduced my machine equipment to the bare minimum. The small Dremel disc sander is probably the machine tool that I use most followed by a Bosch hand drill. In the garage I have a Scheppach Basato bandsaw. The aircraft on the working table is a CA Model Epsilon.
