ORIGINAL: ppkk
My original holes were perfectly aligned, but when I enlarged the holes in the holding blocks to put in the inserts I messed things up. I think the issue is that I went from a #7 drill to a much larger size at once and that messed things up
You are welcome, ppkk.
That is exactly what happened, the big drill bit changed the centerline of the original orifice, that is very common, and even more in soft materials.
One way to avoid it is to fix the fuse under a pressdrill and make diameters bigger for the same hole while keeping the same position.
