RE: YS-170CDI Flight Report
Cutting the prop will not give you the performance in the air that you might want, not loading the engine excessively is the most important thing here, try to get the prop, the idea is to get a smaller diameter propeller to reduce the torque the engine needs to produce when is too tight, 17x12 will do too, but after 10 flights it will not be enough, getting the 17x13 worth it.
Best regards.
