RCU Forums - View Single Post - Multiplex EVO
Old 09-29-2009 | 04:12 PM
dirtybird
Default Multiplex EVO
I think one of the worst mistakes I ever made was buying the EVO. I have had it for about two years and used it very little because of that useless manual. For the last week I have been trying to get some use out of it. Its very frustrating.
I was trying to get it to limit the throttle maximum and be able to switch it out if I want to. I finally got it to do this after reading Jodys tutorial but it still will change the bottom of the travel as well as the top. It says in the manual one of the choices should be one sided but I can't find one.
On the dual rate the switches affect the controls opposite for the aileron and the elevator. In other words when I set sw L for high rate in the up position it is low rate for elevator and visa verse. Nowhere, manual or otherwise, does it tell you how to change this if you can.
