ORIGINAL: misshydro
Here a trick I havent told anyone yet...Ok on new fiblerglass and new plastics parts.. I use etching primer..its a pea green color..It bites into any surfaces to help prime or paint adhears to the surface...I would use the etching spray can primer for Dupi-Color..works great..First I would use a wash it with prepsol/tar&wax&grease remover or wash the boat hull with dishwashing soap.....Then use a red scotchbright pad to scuff the hull down with....then etch prime it then if there no dirt?Then use a tac cloth to wip the hull with to take any dust off the hull....Then you can start painting the hull...
Awesome thanks for the tip!!
Did you happen to find out what or where I can get that shade of Blue from? Oh and do you recommend that I buy the spray gun kit from Harbor Freight, get a smaller airbrush kit, or just use spray cans?
