Four star 60 engine mounting
The back of the firewall is accessable enough to get the blind nuts in (barely). You'll have an easier time if you don't glue in the back half of the tank floor. Set it up so that you can flex the tank floor down after assembly. The tank compartment is kinda tight - you can barely squeeze in a 14oz tank IF you can flex the tank floor.
