RCU Forums - View Single Post - Skymaster L39 build
Old 09-30-2009 | 05:43 AM
Alex48's Avatar
Alex48
Default RE: Skymaster L39 build
Installing the forward cockpit was a real pain. First off I had cut 9mm off the inside edge of the fuz frame to get the cockpit to fit, as it happens this looked much better anyway so I trimmed the canopy frame too. The addition of some internal supports, two slots to help slide it in and some butchery on the cockpit itself had it positioned nicely plus it's easily removable. When
you place the canopy on it helps secure it further. I also re glued the fixing pegs for a neater look. I'll fix the cockpit with a few screws but waiting for the rear cockpit to arrive from Ali.
ID:	1285338   Click image for larger version
ID:	1285339   Click image for larger version
