RCU Forums - View Single Post - Skymaster L39 build
Old 09-30-2009 | 05:47 AM
Alex48's Avatar
Alex48
Default RE: Skymaster L39 build
Before I do the the final fitting out I wanted to improve the internal appearance so It was all sprayed grey, this especially helped the appearance of the canopy frame as it's always visible. I also ordered a decent pilot from www.moderlersloft.co.uk not sure of his fit so just got one to start with. Obviously this all adds weight but with a 120SX there won't be problem however I wouldn't recommend it if using a P80 or similar.
I gave the area behind the rear former that the pipe sits in three coats of ceramic paint just as a precaution as the pipe now sits inside of the top back part of the fuz. I used some heat resistant sleeve and cable clips from Als Hobbies to run the elevator and rudder cables in. It's excellent stuff and really neatens the installation, much better than plastering aluminum tape everywhere. The air rams have been installed onto the mounts I made. All pneumatic tubing has been wire locked on for some extra security. I replaced the main gear door rams with some Ultra precision units, Ive never had a problem with these rams unlike some of the Chinese ones.
Cheers, Alex
ID:	1285343   Click image for larger version
ID:	1285344   Click image for larger version
ID:	1285345   Click image for larger version
