RCU Forums - View Single Post - problems with CVDs
Old 07-01-2003 | 12:54 AM
jswinkos
Default problems with CVDs
dremel a notch in the pin where the setscrew will sit and use loctite on the setscrew. Then, if you want, put heatshrink around the area where the pin is. I personally don't use heatshrink because once you dremel a notch, it won't come out.
