RE: Broken bell crank.
Yes that will do it. I PMed you Kurt. I'm going to get the servo here locally. I'm going for an all metal geared servo. I hope I can get one that is inexpensive. I have no clue as to what to buy. If you don't think that this is bad, my Rustler also has a bad servo and receiver. I haven't used it at all since I got the new receiver and Sidewinder System. I turned it on and the ESC had all of the LED's flashing. So since they are both down, I put the Redcat receiver in the Rustler to test and the ESC worked. If it isn't one thing with me it is something else. Amazing isn't it? You know, there is good luck and bad luck. I've heard people say I'd rather have bad luck than no luck at all. Well, I have no luck at ALL! None!
