BeechCraft D18
Brad....what engines did you use in your Beech.?
If you built another now knowing what you do about locating the CG what if anything would you change in building the aft end to keep it as light as possible.?
Is the washout standard in the Ziroli design or did you add more?
Mine is being built from an Aeroplane works kit......
