RCU Forums - View Single Post - Dynaflite Butterfly build
Old 09-30-2009 | 03:47 PM
  #61
ejam
Default RE: Dynaflite Butterfly build
Well I ended up with everything lining up perfect. The wing sat in the sattle nice and snug, the wings laid out on plans are even and right on the lines. My problem is going to be covering. I started the tail today and have some rinkles. I may be able to heatgun them out.
I have desided to go with bright yellow ultracote on top of fuse, tail and strips on under wing. Transparent blue ultracote on sides of fuse, elev. blue, rudder blue, bottom of fuse yellow and about 5in. yellow on wing tips.The wing will have yellow at the root ribs where sheeting is, then blue all the way till tip of wing where yellow is. Thought that might help make it easy on me with nice straight cuts. I think my son wants to add some army or navy sticker as well since it is his plane!
