RE: Multiplex EVO
I'm not quite sure what you are trying to do with the throttle, could you elaborate? On the D/R switches, go into the setup menu by pressing the button with the monkey-wrench. Then scroll to assignment and enter the menu. then scroll to switches and enter the menu. The first three lines in this menu are your dual rates. By default, each should have an <L in the second column and a downward pointing arrow in the third.
To change them, highlight the DR to change and press enter. You'll see a warning, press enter again. Now, move to the swtich position you want to activate the low rate. Then press enter to save the change.
For example, in your case, it sounds like the Aileron DR has a downward pointing arrow and the elevator has one pointing up. Scroll to the elevator DR and press enter twice. Now flip the L switch to the lower position. You will now see an arrow pointing down with an asterix next to it. Press enter to save and test the DR. it should work properly now.
Tony Ohm
Hitec/Multiplex USA
