RE: Painting vintage wheels
I just use low tack masking tape in small pieces. If you lay the tape on the tire and overlap the edge of the wheel with the tape, you then push the tape against the tire, the tape edge will lodge underneath the wheel. Takes about 2 minutes to mask the tire.
