RCU Forums - View Single Post - JR binding problem
Old 10-01-2009 | 04:19 AM
Mavrik!
Default RE: JR binding problem
ORIGINAL: KC36330
ORIGINAL: tucson
............. I try everything, including moving away from the plane before switching on the receivers.
you should have the receiver powered up and then move the TX away before pushing in the bind button and powering it on, is that how you're doing it? i read that as you're turning on the receiver last and that's not how to do it.
if you are powering them on in the correct order, which binding technique are you using? Smartsafe or Preset?
KC
Can you explain the diff again between smart safe and preset? and what the procedure is again to get the desired outcome for each?
Mav
