RE: 77cc Chrysler ?
I will be using the fly wheel side as that is the side that turns in the correct direction and cutting off the other side so I do have to deal with the left handed threads. And yes I will be using electronic ignition or could go with gas /glow,as I have had good luck with that on some of my other engines and I need to cut down some of the weight.
Also I don't know if you noticed or not but there is a plate on the other side of engine to move the carb to the other side if need be.What if anything would happen if you did this?
tips and suggestions are all welcome.
clocknut
