RCU Forums - View Single Post - EXTRA 330 QUESTION
Old 10-01-2009 | 09:47 PM
TAUMULLER
Default RE: EXTRA 330 QUESTION
Thanks for that advise I will try that test. I did fly the plane this morning.. but had a little oops .
I had the elevator set with to much down trim.. and on take off she bounced hard into the tarmac and caught the prop ..
that exploded into bits and peices ... and catapaulting the plane 25 feet into the grass on wing tips. The only damage was the prop ..
1 wheel pant andmy battery mount . So i put on a 13x8 prop removed the damaged pant and taped the battery in . After setting the elevator trim properly
it took off much better.. a little right aileron trim and some elevator trim and it flew pretty good. I could not put it thru its paces because the battery wasnt really tight.
So I will fix it up .. get a another 13x10 prop and try it again this weekend. It seemed to have plenty of power.. but I did not do any stunts or verticle climbs. Otherwise no bad habits..
stalls nice and straight and flies solid. Landing seemed a little hot but ok. Got a lot of comments on how nice it looked and what gear I had in it.
