IT ARRIVED
Took a fair few weeks for the importer to bring in more stock, but never mind. Finally got mine. All the hardware is already tested and set up, just needs to be fitted now.
I think I'll definitely give the 6S2P a go, the packs fit in (just), but will probably need a new battery tray. More good news: the tail has a nice solid block of balsa so it will be a piece of cake to fit a Dubro tail wheel.
The only disappointment I had was the rudder hardware downgrade. Instead of the nice metal clevises, they added more of the white plastic pushrod connectors to be used. At least the brass wire connectors screw into that, not glued in like the carbon rods, which by the way I am replacing with Dubro hardware on both rod ends. Just need to find a die to cut the thread on the 4-40 control rods...
