RCU Forums - View Single Post - Dynaflite Butterfly build
Old 10-02-2009 | 02:58 PM
  #67
ejam
Default RE: Dynaflite Butterfly build
Hey, thanks. Im getting a little better with covering as I go along. Yes temp is your friend. It is very important knowing what temp is. On my iron, there is no numbers, so I used my digt. therm. to find the right 220 for Ultracote. Then after it has all adheired to wood, set temp higher,about 235 and run over again to take wrinkles out.
My covering is not perfect, but is getting better!
I am thinking about adding some web pieces to the outer wing panel, and maybe sheet the two outer rib areas to make it easier to apply the yellow covering at the tip.
