RE: G75 compression loss
From his post: Head is shimmed an extra .008" higher than stock
I would say the extra .008 head shim you have in there would tend to lower your compression a little.[sm=idea.gif] Are you a self proclaimed engine guro, that you felt you needed to add a head shim and then wonder why the compression is less.[sm=idea.gif]
