RCU Forums - View Single Post - Mounting prop on slow stick
Thread
10-03-2009 | 04:30 PM
2
Arkitexas
Dec 2005
54
Bryan, TX
RE: Mounting prop on slow stick
My understanding is that the GWS Slow Stick comes with a "prop adapter" (set screw of adapter can barely be seen in the left picture). Depending upon the prop source, you may need to ream or drill out the prop hole until it fits the adapter shaft.
To protect the prop from damage, many flyers use "prop savers" instead (in right picture shown without rubber band or o-ring). Again, the prop may need to be reamed or drilled. The prop saver holds the prop with a rubber band giving an elastic property to the mounting.
Rick
Reply
Like
Arkitexas
View Public Profile
Send a private message to Arkitexas
Find More Posts by Arkitexas
View iTrader Profile
