RCU Forums - View Single Post - Evolution/MVVS Ignition
Old 10-03-2009 | 10:11 PM
ggroyal1's Avatar
ggroyal1
Default Evolution/MVVS Ignition
I have a two ignition systems, one is for the Evolution 58, the other is for a MVVS 26.
The Evolution label: ICU-l S/N13298 D:11/08 240M20
The MVVS label: ICU-L S/N 12139 D:05/08 240M20
How do you tell which engine it is for?
You can change the timing on the MVVS 26, you can't on the Evolution 58. Horizon told me that was correct, you can't change the timing.
I might have an ignition problem(spits and sputters) on the Evolution and I wanted to swap it with MVVS ignition because it is not in a plane.
George G. Royal
ID:	1287843   Click image for larger version
